quickMOUNT pro Bracket .. how to block movements?
i can’t find how to completely stop horizontal and vertical movements when using quickMOUNT pro bracket with, by example, LHG antennas or mANTBox sector access points.
I usually tighten the blocking screws with a lot of effort, but anyway, anytime, the antenna could move a lot through the 4 directions without any big load on in it (just applying a little finger power on the plastic case of the antenna!).
Please, tell me.. am i doing something wrong or isn’t it that the quickMOUNT is simply a nasty unusable plastic bracket?
Many thanks
Giova
Try this
https://mikrotik.com/mfm
