Originally created a standard and guest network with QuickSet, no probs.
After disabling 5GHz and playing with the SSID's looks like my "Guest Network" is no longer there.
After checking Quickset, Guest Network SSID is blank.
Tried: /interface vlan print and get nothing.
Tried disabling my "supposed" guest network SSID under WiFi and adding SSID under QuickSet but not working? What's the simplest way to reset QuickSet so I can start over? Don't want to reset everything else, because I already made changes that took me hours to figure out.
Sorry, but as the user forum has repeatedly stated (it would be better if users were in charge),
QuickSet should only be used once, and that's it.
Then it should disappear into the cosmic void.
Because whatever you do afterward compromises everything,
and QuickSet is completely unusable, and if used make the device to be resetted again from scratch.
You can post your full config (I write FULL) with /export on terminal,
redacting (I write REDACTING, not deleting) sensitive info like username, passwords, emails, public IPs and serial number,
to have other users check it to help you pinpoint the problem.
By examining exported configuration. Hence recommendation by @rextended to post it here. We don't expect inexperienced users to be able to fully understand some random configuration, but there are users that are fluent in ROSish.
