After logging to webfig, is it possible to show quick set CPE mode as the default one? Right now I can see as default WISP AP. I was customize skins, but can’t see this option. The perfect would be to show just CPE without possibility to change.
I’m using Mikrotik mAP v. 7.12.1, I need it because, want to make this router as a gateway for a devices which will be connected to the cloud. Need to create a configuration that endusers will connect from smartphone by WiFi to the router and set connection with Wireless Internet. This configuration has to be done as easiest as possible for a endusers.
Thanks for the replies.
Anyone knows the answer?
Or maybe there is a way by hotspot function to give possibility to set SSID and password for wifi connection in CPE mode? I know that hot spot is made for something else, but maybe here could be a workaround?
