Quickset VPN - router access
We enabled the quickset VPN feature. I can connect fine via L2TP / IPsec on a Mac. I can even route all traffic through my VPN and it works fine (public IP changes, sites are accessible, etc.).
I can’t however access the router on the 192.168.89.1 or 192.168.88.1 IP addresses. Is there some firewall rule or other change required to enable access to the router?
The quickset documentation states “If you want to access your local network (and your router) from the internet,” (emphasis mine, https://wiki.mikrotik.com/wiki/Manual:Quickset#VPN).
Thanks!
The firewall is using accesslists (called WAN and LAN) to determine (on the input chain) who can access the router. Probably the VPN IP addresses/interface is not part of LAN and can’t therefor access the router.
Did you make any changes on the firewall yourself?
Can you please stop using Quickset (as it could mess up your config)?
No other changes beyond quickset. Trying to support someone in setting up their router themselves that I don’t have access to.
I see, perhaps if I assign an LT2P Server Binding for the “vpn” user and add it to the LAN interface list it will work! Will try and report back.
So big thing with using the server binding interface is that they are usually dynamic so once the user logs out that interface will be gone and once they log back in again unfortunately it will not be picked up as the same interface.
This is an easy fix, if you go to the vpn server and double click on the dynamic binding there should be a copy button just hit that then hit ok or apply, all that is needed to be done in terms of configuration. You will notice their dynamic binding still there but that will go away once they log off and when they log on again they will use the static binding :slight_smile:
Make sure to set the static binding in the list rather than the dynamic and your interface will be added to the interface list properly.
