quickset
On the batch of RB2011UAS-2HND-IN quickset is missing? is there a way to enable it?
what RouterOS version you are running?
I had to enable wireless in the packages. After that the quickset showed up.
Before I didn’t have to do that.
use latest routeros
router os 6.4 made no difference.
Solution: enable the wireless package.
Seems its not enabled by default anymore.
t
Had same issue with wireless not showing up had to enable.
V6.5 Issue with quick Set.
New RB2011UAS-2HnD out of the box. Upgraded 6.1 to 6.5 RouterOS.
Quickset in AP mode
Under LAN/WLAN section says DHCP Server is unchecked however from a default config DHCP is enabled
Quickset doesn’t show correct information?
2013-10-22 10_46_33-admin@192.168.88.1 (MikroTik) - WinBox v6.5 on RB2011UAS-2HnD (mipsbe).jpg
