First time I used function “Quick Set”. When I pressed OK, my interfaces for Internet and for Local network was changed. I not known about it. My router was stopped work and it takes time to find what was problem.
My suggestion for Quick Set is:
not change defined interfaces when same address/network is used
or better
add interfaces option to Quick Set Internet and Local network options!
I have RB1100 configured. I use it several years, at weekend I upgraded from version 6.13 to 6.19. (Maybe same problem occurs also after upgrade, but I’m not sure.) What I’m sure, when I use Quick Set, interfaces will changes.
OK means apply the config that Quickset is showing you
Of course, but Quickset not showig about changing interfaces. I only suggest improvements, because changing interfaces is not expected when OK is pressed.
