Quickset
I have two rb 450,s & one 750gl. I have set all three v6.28 for a default hot spot on eth 3 using dhcp on the eth1 gateway. every thing works ok, until I use quickset to set the wan port to a static ip address & the routers all lock up the hotspot
with no internet access but can access with winbox etc , hotspot severs are disabled & I have to reset hotspot config or restore backup ??? Then I net installed 5.xx on one of the 450.s & 750gl & using
ip xxx.xxx.xxx.xx/cfg can switch between DHCP or Static address on the gateway with no issues.??
