hi,
i ve a routerboard that i want reset configuration and setup it again.
My rb is attached at modem router on eth1 port. Lan bring up from the others
gigabit ports.
I want to connect to internet with eth1 wan
My dsl modem ip is 10.0.0.1 and ip rb should be 10.0.2.1 with the dhcp range from 2.21 to 2.254
because i ve reserved 2.2 to 2.20 for fixed ip . All device lan has fix ip with dns ip of rouoterboard.
how is a step by step procedure with winbox to set this full functionally?
hi,
no help?
Inviato dal mio GT-I9300 con Tapatalk 2
