Try following: [I have used it in Ubuntu Freeradius 2.x with Mikrotik 5.x]
QUOTA LIMIT FOR USER with CUSTOM MEANINGFUL REJECT REPLY MESSAGE
To limit user data volume limit (either daily, weekly or monthly, set this in reset section) use below code.
edit the file /etc/freeradius/sites-enabled/default
and add following under “authorize {“ section
totalbytecounter{
reject = 1
if(reject){
update reply {
Reply-Message := "ZAIB-RADIUS-REPLY - You have reached your bandwidth limit"
reject
now edit file /etc/freeradius/modules/sqlcounter_expire_on_login
Add Following
sqlcounter totalbytecounter {
counter-name = Mikrotik-Total-Limit
check-name = Mikrotik-Total-Limit
reply-name = Mikrotik-Total-Limit
sqlmod-inst = sql
key = User-Name
reset = never
query = “SELECT ((SUM(AcctInputOctets)+SUM(AcctOutputOctets))) FROM radacct WHERE UserName=‘%{%k}’”
Save and Exit.
Now add user attribute in radchceck table (Following is 1 MB total data limit example, which can be used in parts as well )
Note: Value is in bytes, so use it accordingly
INSERT INTO radcheck ( id , UserName , Attribute , op , Value ) VALUES (NULL , 'zaib', 'Mikrotik-Total-Limit', '=', '1000000');
Once the user quota over, and user retry login he will get access deny message, and in radius log, you can see following
