I’ve just had to return my first (and last) RB333 to my distributor as although the board powered up every time it failed to boot three times out of four, regardless of whether I was using PoE or jack - tho’ in truth I was unhappy with the design which piled three radio cards on top of each other (Cross-talk? Heat?), and its minimum power requirement of 12v which is a problem when you’re using batteries on a remote site.
I gather it wasn’t the first 333 he’s had returned with the same problem and he’s no-longer supplying them. I have a need for three cards in this situation but the 433 won’t be available in this neck of the woods for at least another three weeks and the RB600 won’t fit in any enclosure I use.
My distributor has no 532s left but fortunately has a couple of daughterboards for them left and I do have a 532 I can pull from another location so with that and a daughterboard should be able to get the site running in a couple of days.
I’ve also had problems with the 133 that I never had with the 112. In fact I had a superbly functioning, trouble-free network built on the 112 and the 532, and the 532As with their 400MHz CPUs, 128MB hdd and extension memory slots I found to be rugged and reliable and quite fast enough to handle anything I was ever likely to throw at them.
I miss them. R.I.P. 532 - victim of change for the sake of marketing.
