R.OS 3.20 : Queues don´t work
sorry my english
i´ve installed 3.20 version
i found other users with the same problem
does exist any package to solve the problem?
thanks, lst
if ur simple queue type is default-small, make it default.
thnxs,
raktim
don´t work either
i tried with all types of queue
if you use bridge - /interface bridge settings set use-ip-firewall=yes
dont´t use bridge.
i don´t use webproxy, it can be relationated with the problem? it shouldn´t
do you use ‘xen’ package?
xen package installed but no entries add,
the only package that i didn´t install was mpls-test
If xen package is installed then queues are not working at all. Uninstall xen
THANK YOU
it´s working now
desinstalling XEN package and setting the type of queue as “default”
