Dear All,
I have some problem in ,y bridging network that show in the following pic:
Dear All,
If you want to make transparent network, you may use WDS to establish it,
http://wiki.mikrotik.com/wiki/Wireless_repeater
thanx Dear for your response..
I do this setting and there are problem in the setreaming of traffic, each 5 munite the switch of ISP restarting,
I think there are loop back in the some of point
anyone have any idea??
I’m not aware which interfaces you have bridged.
Enable rstp on MikroTik bridge, it will help you to cooperate with network loop.
Please, check careful bridge configuration.
Thanx dear for your help
i will explain:
the (1) RB433AH have the following confige
interface : ether1 (enable) and bridge1 and wlan1
bridge : STP and ports : ether1 and wlan1
wirless : mode:bridge band 5ghz freq 8150 wds dyanmic interface bridge1
ip address : x.x.x.x public ip have interface ether1
the last problem accur : if disable wlan1 the rb running else the public switch is restarting every 5 munite
thanx for all if there are any idea…
