MTU is 1500
If I select only B3 or only B7, the modem does not register to the network. It shows “functionality: full”, but nothing else. The only way it registers to the network is to uncheck all bands and then it connects as I posted above.
To be honest, and while I really appreciate your responses and help, I have a hard time understanding the actual meaning or guidance on what should I do.
I am basically looking into the issue why my LTE is so slow when compared to marketed speed of the R11-LTE6 module and I am struggling with finding the correct settings. Currently I am getting around 10-15Mbps max (based on speedtest).
[admin@MikroTik] /interface lte> at-chat 0 input=“at+eemginfo?”
output: +EEMLTESVC: 561, 2, 1, 2007, 147, 6300, 24300, 20, 10, 30, 11, -1, 2,
10, 0, 1, 0, 32768, 25, 4001435959, 2620939, 255, 0, 4, 9, 18, 6,
14, 30, 0, 0, 0, 0, 0, 0, 0, 0, 27, 766, 0, 0, 0, 1, 0, 92, 305, 0,
0, 0, 0 +EEMLTEINTER: 0, 147, 150, 13, 6 +EEMLTEINTRA: 0, 9, 6300,
24, 4 +EEMLTEINTRA: 1, 149, 6300, 30, 14 +EEMLTEINTRA: 2, 148, 6300,
25, 3
[admin@MikroTik] > interface lte info lte1 once
pin-status: ok
registration-status: registered
functionality: full
manufacturer: “MikroTik”
model: “R11e-LTE6”
revision: R11e-LTE6_V025
current-operator: 23101
lac: 2007
current-cellid: 2620939
enb-id: 10238
sector-id: 11
phy-cellid: 147
access-technology: LTE (CA2)
session-uptime: 8m34s
imei:
imsi:
uicc:
subscriber-number: “My Number”,“”,145
primary-band: B20@10Mhz earfcn: 6300 phy-cellid: 147
ca-band: B1@10Mhz earfcn: 150 phy-cellid: 147
rsrp: -110dBm
rsrq: -13.5dB
sinr: 0dB
Thank you very much
Michael
