Hello
I just started learning to use the RourterOS, get a new R11e-5HacD installed and is unable to be recognized by RouterOS, I have tested the new card on a RB912UAG-5HPnD I borrowed, It’s recognized by RB912UAG-5HPnD and working fine, I also installed other old wifi card and I can see that the old wifi card is recognized by the system as wlan1, Both cards can be seen inside the system resource, So what is this situation? Do I need to install the driver? or the RouterOS X86 version does not support R11e-5HacD ? Please help me here .
[admin@MikroTik] > system resource print
uptime: 29m12s
version: 6.42.5 (stable)
build-time: Jun/26/2018 12:12:08
free-memory: 1820.9MiB
total-memory: 1893.5MiB
cpu: Intel(R)
cpu-count: 8
cpu-frequency: 2199MHz
cpu-load: 0%
free-hdd-space: 3684.5MiB
total-hdd-space: 3779.0MiB
write-sect-since-reboot: 600
write-sect-total: 600
architecture-name: x86
board-name: x86
platform: MikroTik
[admin@MikroTik] /interface wireless> print advanced detail
0 X name="wlan1" mtu=1500 l2mtu=1600 mac-address=50:B7:C3:62:4A:86 arp=enabled disable-running-check=no
interface-type=Atheros AR9300 radio-name="50B7C3624A86" mode=station ssid="MikroTik" area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=2412 band=2ghz-b/g
channel-width=20mhz secondary-channel="" scan-list=default wireless-protocol=any rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps
max-station-count=2007 distance=dynamic tx-power-mode=default noise-floor-threshold=default
nv2-noise-floor-offset=default vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
wmm-support=disabled hide-ssid=no security-profile=default wps-mode=push-button station-roaming=enabled
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
station-bridge-clone-mac=00:00:00:00:00:00 ampdu-priorities=0 guard-interval=any
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-
15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 tx-chains=0 rx-chains=0 amsdu-limit=8192
amsdu-threshold=8192 tdma-period-size=2 nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30 nv2-security=disabled
nv2-preshared-key="" nv2-mode=dynamic-downlink nv2-downlink-ratio=50 nv2-sync-secret="" hw-retries=7
frame-lifetime=0 adaptive-noise-immunity=none hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 frequency-offset=0 rate-selection=advanced multicast-helper=default
multicast-buffering=enabled keepalive-frames=enabled pci-info="06:00.0"
[admin@MikroTik] > system resource pci print detail
0 device="0c:00.3" name="unknown device (rev: 1)" vendor="Intel Corporation" category="Et
vendor-id="0x8086" device-id="0x1521" irq=11 memory=0xFB600000-0xFB6FFFFF,0xFB680000-0x
1 device="0c:00.2" name="unknown device (rev: 1)" vendor="Intel Corporation" category="Et
vendor-id="0x8086" device-id="0x1521" irq=5 memory=0xFB620000-0xFB63FFFF,0xFB684000-0xF
2 device="0c:00.1" name="unknown device (rev: 1)" vendor="Intel Corporation" category="Et
vendor-id="0x8086" device-id="0x1521" irq=10 memory=0xFB640000-0xFB65FFFF,0xFB688000-0x
3 device="0c:00.0" name="unknown device (rev: 1)" vendor="Intel Corporation" category="Et
vendor-id="0x8086" device-id="0x1521" irq=11 memory=0xFB660000-0xFB67FFFF,0xFB68C000-0x
4 device="0b:00.0" name="ASPEED Graphics Family (rev: 48)" vendor="ASPEED Technology, Inc
category="VGA compatible controller" vendor-id="0x1a03" device-id="0x2000" irq=11
memory=0xFA000000-0xFB0FFFFF,0xFB000000-0xFB01FFFF io=0xC000-0xCFFF
5 device="0a:00.0" name="unknown device (rev: 3)" vendor="ASPEED Technology, Inc." catego
vendor-id="0x1a03" device-id="0x1150" irq=0
6 device="09:00.0" name="unknown device (rev: 0)" vendor="Atheros Communications Inc." ca
vendor-id="0x168c" device-id="0x003c" irq=11 memory=0xFB200000-0xFB4FFFFF
7 device="08:00.0" name="unknown device (rev: 3)" vendor="Intel Corporation" category="Et
vendor-id="0x8086" device-id="0x1533" irq=10 memory=0xFB700000-0xFB7FFFFF,0xFB780000-0x
8 device="07:00.0" name="unknown device (rev: 3)" vendor="Intel Corporation" category="Et
vendor-id="0x8086" device-id="0x1533" irq=11 memory=0xFB800000-0xFB8FFFFF,0xFB880000-0x
9 device="06:00.0" name="unknown device (rev: 1)" vendor="Atheros Communications Inc." ca
vendor-id="0x168c" device-id="0x0032" irq=11 memory=0xFB900000-0xFB9FFFFF
