R11e-5HacD not recognized into x86
as stated in object i installed the miniPCI-e card into x86 but routeros does not see additional wlan over its embedded.
[roger@MikroTik] /system resource pci> pr detail
1 device=“03:00.0” name=“unknown device (rev: 0)” vendor=“Atheros Communications Inc.”
category=“Network controller” vendor-id=“0x168c” device-id=“0x003c” irq=11
memory=0xFD200000-0xFD3FFFFF
firmware version 6.39.1,
I also tried using the wireless-fp and wireless-cm2 in the 6.34.6 package, but still unrecognizable.
Any suggestion ?
I have another device RouterBOARD 952Ui-5ac2nD pci interface in the same can not be identified, but it can interface in the normal use.
fw version 6.39.1
0 device=“00:00.0” name=“unknown device (rev: 0)” vendor=“Atheros Communications Inc.”
category=“Network controller” vendor-id=“0x168c” device-id=“0x0050” irq=2 memory=0x10000000-0x11FFFFFF
[roger@RogerStation] /interface> pr detail
5 R name=“wlan1” default-name=“wlan1” type=“wlan” mtu=1500 actual-mtu=1500 l2mtu=1600 max-l2mtu=2290
mac-address=64:D1:54:1A:26:10 fast-path=yes last-link-down-time=jun/05/2017 11:51:36
last-link-up-time=jun/05/2017 11:51:38 link-downs=1
6 RS name=“wlan2” default-name=“wlan2” type=“wlan” mtu=1500 actual-mtu=1500 l2mtu=1600 max-l2mtu=2290
mac-address=64:D1:54:1A:26:0F fast-path=yes last-link-down-time=jun/05/2017 11:46:25
last-link-up-time=jun/05/2017 11:47:39 link-downs=1
I do not know if this is not yet supported by x86 ?
Hello
Is there any goods new on version 7.x?
I’m planning to buy R11e-5HacD for my x86 but still considering.
Update:
I just put r11e-5hacd on my x86 (j4125) and it works BUT 5ghz only, it does not provide 2.4ghz band.
Routeros vers 7.7
R11e-5HacD only specifies support for 5GHz band … so if hardware can’t do it, no driver can change that.
