R11e-5HacD on 5Mhz & 10Mhz
Hello Everyone.
I have a RB922UAGS-5HPacD card with an additional R11e-5HacD card attached, and would like to use 802.11n with 10 or 5 MHz.
The RB922 has no issues, but the R11e seems to be.
I found an article where no one has answered here , and another one here , about the R11e-2HnD, and this got fixed.
Shouldn’t the 5HacD also work on 10 & 5 MHz on 802.11n ?
Running version: 6.42.3
Thank you in advance.
All 802.11ac cards/Boards/ROS from Mikrotik only supports 20,40,80 MHz and nothing else.
5,10,30,60mhz are not avaible, the only way bye it from another vendor…
Hi.
Thank you for the response.
Would then R11E-5HND be the correct card since it is not an AC card?
You mention that I would have to buy from another vendor, but would they work with the RB922 card?
n card will work,
if you need ac with 10 MHz Channel buy something else..
