R11e-LoRa9/R11e-LoRa8 supported RB hardware
Is there a list of supported RB devices that the R11e-LoRa9/R11e-LoRa8 will work in? The documentation says “It enables LoRaWAN connectivity for any MikroTik product that
has mini PCIe slot with connected USB lines” but which ones have the USB port on the mPCIe port? Do they all or are there ones that are known NOT to have USB? As an example, I have a RB912R-2nD-LTm but does it have USB on the mPCIe port?
-Chris
In other terms, it will work on any device which could be used with an LTE modem. It can be used with any of our products that have miniPCI-e slot (exceptions RB800 and RB4011).
Also, if you have miniPCI-e to USB adapter, you could also connect the LoRa card to any RouterBoard with USB port, for example, your CCR1036, hAP ac^2 etc. Yes, it will also work with your RB912.
Same issue here. No shown device (LoRa8) in RB912UAG-2HPnD.
Installed lora package in RouterOS v6.46.1
Any ideas?
Found the solution.
Just enter the tab:
SYSTEM - ROUTERBOARD - USB and set the USB Type to: Mini PCIe
That will do the trick und the LoRa8 device appears in the list.
I`m glad you figured it out. This is an good example showing that LoRa need those USB lines.
Does anyone know if an RBM33G supports a LoRa card AND a cellular modem?
I’m trying to sort a very low power LoRa gateway for remote solar operation, so need two mPCI slots
i am using several RBM33G with LoRa8 and LTE card without problems.
you have to set a jumper to route the USB2.0 lines to the second PCIe slot
Thanks, still deciding on the RBM33G or LtAP. The RBM33G looks like it will use less power which is a bonus for me on remote solar powered LoRa gateways.
