R11e-LTE Packet loss
Hello everyone,
I am currently using an LtAP mini with a R11e-LTE routerboard inside and am finding it quite useful however I am getting strange packet loss on the lte interface which is not happening on any other LTE devices in the same room (phone, tablet, etc…).
The connection will function fine for 2-3 minutes then timeout for a few seconds which is quite frustrating as it will cause my VPN tunnels to drop, this packet loss occurs on the internal antenna and also 2 different external antennae. Has anyone else experienced similar issues or have any suggegstions to troubleshoot further? See below for an example.
[admin@MikroTik] > ping 8.8.8.8
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 8.8.8.8                                    56  54 153ms
    1 8.8.8.8                                    56  54 70ms
    2 8.8.8.8                                    56  54 145ms
    3 8.8.8.8                                    56  54 243ms
    4 8.8.8.8                                    56  54 432ms
    5 8.8.8.8                                    56  54 158ms
    6 8.8.8.8                                    56  54 103ms
    7 8.8.8.8                                    56  54 242ms
    8 8.8.8.8                                    56  54 271ms
    9 8.8.8.8                                    56  54 70ms
   10 8.8.8.8                                    56  54 45ms
   11 8.8.8.8                                    56  54 138ms
   12 8.8.8.8                                    56  54 142ms
   13 8.8.8.8                                    56  54 312ms
   14 8.8.8.8                                    56  54 175ms
   15 8.8.8.8                                    56  54 183ms
   16 8.8.8.8                                    56  54 55ms
   17 8.8.8.8                                    56  54 48ms
   18 8.8.8.8                                    56  54 210ms
   19 8.8.8.8                                    56  54 51ms
    sent=20 received=20 packet-loss=0% min-rtt=45ms avg-rtt=162ms max-rtt=432ms
   20 8.8.8.8                                    56  54 197ms
   21 8.8.8.8                                    56  54 224ms
   22 8.8.8.8                                    56  54 371ms
   23 8.8.8.8                                    56  54 118ms
   24 8.8.8.8                                    56  54 50ms
   25 8.8.8.8                                    56  54 292ms
   26 8.8.8.8                                    56  54 176ms
   27 8.8.8.8                                                 timeout
   28 8.8.8.8                                                 timeout
   29 8.8.8.8                                                 timeout
   30 8.8.8.8                                                 timeout
   31 8.8.8.8                                                 timeout
   32 8.8.8.8                                                 timeout
   33 8.8.8.8                                                 timeout
   34 8.8.8.8                                                 timeout
   35 8.8.8.8                                                 timeout
   36 8.8.8.8                                                 timeout
   37 8.8.8.8                                                 timeout
   38 8.8.8.8                                                 timeout
   39 8.8.8.8                                                 timeout
    sent=40 received=27 packet-loss=32% min-rtt=45ms avg-rtt=173ms
   max-rtt=432ms
   40 8.8.8.8                                                 timeout
   41 8.8.8.8                                                 timeout
   42 8.8.8.8                                                 timeout
   43 8.8.8.8                                                 timeout
   44 8.8.8.8                                                 timeout
   45 8.8.8.8                                                 timeout
   46 8.8.8.8                                                 timeout
   47 8.8.8.8                                    56  54 38ms
   48 8.8.8.8                                    56  54 45ms
   49 8.8.8.8                                    56  54 45ms
   50 8.8.8.8                                    56  54 45ms
   51 8.8.8.8                                    56  54 38ms
   52 8.8.8.8                                    56  54 37ms
   53 8.8.8.8                                    56  54 45ms
   54 8.8.8.8                                    56  54 38ms
   55 8.8.8.8                                    56  54 36ms
   56 8.8.8.8                                    56  54 68ms
   57 8.8.8.8                                    56  54 33ms
   58 8.8.8.8                                    56  54 37ms
   59 8.8.8.8                                    56  54 97ms
    sent=60 received=40 packet-loss=33% min-rtt=33ms avg-rtt=131ms
   max-rtt=432ms
Cheers,
Dylan
First, be sure that you use the latest MODEM FIRMWARE to MikroTik_CP_2.160.000_v015 by
Change to upgrade=yes
[marcin.przysowa@SXTR_LTE6] > interface lte firmware-upgrade lte1 upgrade=no
  installed: R11e-LTE6_V024
     latest: R11e-LTE6_V020
Remember about documentation: https://wiki.mikrotik.com/wiki/Manual:Interface/LTE#Modem_firmware_upgrade
Thanks for the reply, I had already ensured I was running the latest firmware for the modem and RouterOS/RouterBoard, I am thinking it has to just be an issue with my antennae.
[admin@MikroTik] > interface lte firmware-upgrade lte1 upgrade=no
  installed: MikroTik_CP_2.160.000_v015
     latest: MikroTik_CP_2.160.000_v015
[admin@MikroTik] >
Cheers,
Dylan
how did you get V024 firmware?
When you found problems with working product and write to support@mikrotik.com then you can finish with not-published Beta version of ROS/ModemFirmware/Boot-Firmware etc.
