The R11e-LTE modem connected via usb is not detected as an LTE device (lte1) in RB951Ui-2HnD. At the same time, it is easily detected and works as LTE modem in the RB952Ui-5ac2nD-TC. Both running ROS 7.6.
I also tried to downgrade RB to version 6.49.7, it did not help, the modem is not detected as a LTE device.
Is there any way to run the R11e-LTE on RB951 the same way it works on RB952Ui?
RB951Ui-2HnD
[admin@MikroTik] > /system resource usb print
Columns: DEVICE, VENDOR, NAME, SPEED
# DEVICE VENDOR NAME SPEED
0 1-0 Linux 5.6.3 ehci_hcd RB400 EHCI 480
1 1-1 R11e-LTE 480
[admin@MikroTik] > /port print
Columns: NAME, CHANNELS, BAUD-RATE
# NAME CHANNELS BAUD-RATE
0 usb1 1 9600
RB952Ui-5ac2nD-TC
[code][admin@MikroTik] > /system resource usb print
1 1-1 MikroTik R11e-LTE 480
0 usb1 1 9600
[admin@MikroTik] > /interface lte print
Flags: R - RUNNING
Columns: NAME, MTU, NETWORK-MODE, APN-PROFILES
# NAME MTU NETWORK-MODE APN-PROFILES
0 R lte1 1480 gsm default
3g
lte
