Hi, here some data.
Note that I’m using the latest RouterOS beta, theare are no differences in this behaviour. I wanted to test the new updates to see if something was changing.
When I’m connected to the BTS with CA enabled (I’ve removed info like the IMEI):
[admin@Huawei] > interface lte monitor lte1
pin-status: ok
registration-status: registered
functionality: full
manufacturer: "MikroTik"
model: "R11e-LTE6"
revision: R11e-LTE6_V020
current-operator: 22288
lac: 24372
current-cellid: 61994765
enb-id: 242167
sector-id: 13
phy-cellid: 143
access-technology: Evolved 3G (LTE CA2)
session-uptime: 3s
imei:
imsi:
uicc:
primary-band: B7@20Mhz earfcn: 3350 phy-cellid: 143
ca-band: B3@20Mhz earfcn: 1650 phy-cellid: 359
rssi: -54dBm
rsrp: -91dBm
rsrq: -12.5dB
sinr: 1dB
After some seconds, the connection is lost and:
pin-status: ok
registration-status: not searching
functionality: tx and rx rf circuit disabled
model: "R11e-LTE6"
session-uptime: 18s
imei:
imsi:
uicc:
This is the output of the command you asked:
[admin@Huawei] > interface lte at-chat 0 input="at+eemginfo\?"
output: +EEMLTESVC: 546, 2, 136, 24372, 143, 3350, 21350, 7, 20, 45, 242, -3, 2, 10, 0, 1, 0, 65001, 48, 4064677188, 61994765, 255, 0, 3, 46, 47, 17, 19, 65, 5, 108, 0, 0, 0, 0, 0, 0, 0, 13556, 0, 0, 0, 1, 0, 0, 218, 0, 0, 0, 0 +EEMLTEINTRA: 0, 148, 3350, 45, 9
I’ve noticed that I’ve the same issue using CA with band 7 and 20. I can work without issue with B1+B20, for example.
