Hey
I’m looking for any and all feedback on field-testing of R11e-LTE6.
Please share your findings.
Kind regards
Sebastian
Hey
Kind regards
Sebastian
I have got “SXTR rev2 & R11e-LTE6 kit” by 1 day.
SIM are not up/down but a/b.
2CA works. Cell/SectorID lock works for primary band and second one “ca-band” works automatical. This lock is now save inside modem, we not must use modem-init.
It’s inside house now. I prepare place outsite at 5m up.
My BTS is 3km at 80m up.
At MikroTik webpage this model have got a bandwitch 197Mbs on Ethernet then maybe a RB chip have got seared 2xFastEthernet.
I must grab a new ISP simcard and then I go to City to check this max transfer via LTE and check if bonding at both Ethernet give me 100Mb or 200Mb limitation.
Thx.
Interesting info. A bit early, as you only got it, but I would like to hear your findings on link / connection stability.
Stability… at 2xCA it’s like the car with 4x4 ![]()
SXTR have two vlans, one is passthrough lte. Second one is mgmt and grab internet for itself.
I try grab a logs about changing 2xCA etc.
I try do own scripts loging lte info parameters and send it to remote syslog (TheDude in LAN)
For now it’s just work.
SNMP not give signals or lte info parameters - I cannot just create in TheDude snmp probe and do graphs :(.
Next test’s will be checking all 4 ISP in PL with different BTS. This tests results will be with most common external Antenna’s as table’s.
Next situation will be to recreate the same test with LHGR&R11e-LTE6 when he will be accessibility in PL (december).
