R11e-LTE6 firmware and AT commands doc
Hi
Where can I find documentation for the R11e-LTE6 modem?
I can’t find for example changes in the firmware, which has changed for example between the v20 and v25 versions. I found on the forum that version 25 works worse for some http://forum.mikrotik.com/t/r11e-lte6-v025-firmware-very-hard-to-get-ca-up/138469/1
I used to have a SIM76 SIM7600e modem and was able to issue temperature and voltage via AT commands. Is there such a thing?
I connected the modem to hAP lite through a mini pci-e to usb adapter https://vovanys.com/all/mikrotik-hap-lite-i-r11e-lte6/
Updating via the command
/interface lte firmware-upgrade lte1 upgrade = yes
always ends with status: failed and rebooting the modem
Only at: https://wiki.mikrotik.com/wiki/Manual:Interface/LTE
I can’t find for example changes in the firmware, which has changed for example between the v20 and v25 versions. I found on the forum that version 25 works worse for some > http://forum.mikrotik.com/t/r11e-lte6-v025-firmware-very-hard-to-get-ca-up/138469/1
Release Note - not exist or not publishted to us. v25 fix many stuff but CA not work with Freq/Cell Lock but this fw is more stable. v25 do some DL+DL but this is just litle compare to EP06-E.
NO :frowning:
Why this is important? I know about situation when some person use m.2->mPCIe adapter to use EM12 and that adapter use a temp. problems.
I connected the modem to hAP lite through a mini pci-e to usb adapter > https://vovanys.com/all/mikrotik-hap-lite-i-r11e-lte6/
This should be ~“answer”
https://wiki.mikrotik.com/wiki/Manual:Interface/LTE#mPCIe_modems_with_RB9xx_series_devices
