R52 or R52H
Hello, which wireless card is best for my 2018 flat panel CPE? The R52 or R52H? which is best for long range 2.4ghz frequenct P2P?
they are the same, except R52H has more output power. if there is no noise, the high power will be a benefit.
any other card I can use on the 2018 to achieve greater distance on 2.4ghz?
