R52 vs R52H temp rating
I just noticed that the R52 is only rated for 0c and the R52H and all other MT products seem to be rated for at least -20c or better. I know the R52 has been out for a bit but I would like to here from someone using them in a very cold climate. We can see -40c on occasion here and If it is going to be an issue I’d rather swap them out before winter comes :smiley:
Erik
it must be a typo, or mistake. those temp specs are not accurate. we will check.
I would also like to know what the R52H resistance to static is, as the R52 had very poor performance in static environments?
Albie
