R52
I can’t seem to get an answer for this.
When R52 is set to a 5 or 10 mhz channel does it listen on the same 5 or 10 mhz channel? Or is it like the CM9 and listens on a larger channel?
Hydro
What will it take to get this answered?
Hydro
I have read (on this forum) that the r52 does indeed listen on 5/10mhz channels and cm9 ill only listen on 20mhz.
I cannot say for sure vut I have read it a few times.
It would be best if teh Manuafacture jump in and answer?
From searching the forums it seems the manufacture always avoids answering this question. So to me that means it must be worse than the CM9.
Hydro
we simply don’t have this information, as this feature (5/10Mhz) is unofficial and not documented. Is there even a way to test this?
I guess when one of us gets time, but a couple in a rb with close channels and speed test
Then to same with cm9
I can’t speak for R52, but i can speak for CM9.
CM9 (and all AR-5213) could :
  • Transmit & Receive at : 20 & 40 Mhz
  • Transmit at 5,10,20 Mhz, but receive at 20 Mhz.
How to test ?
Simple, get a few RB :
  • Mode 5 Ghz : scan
  • Mode 5 Ghz : 10 mhz → scan
  • Mode 5 Ghz : 5 mhz → scan
High Regards,
Andrei
