hi
i have R52H can i used it to connect with MiMo Sector Antennas to transmit as V , H in same time
this sector have 2x2 MiMo (Dual Polarization H and V) from RF elements s.r.o.
Okay, do you have a question?
can transmit as V , H in same time
with R52 H
Polarization is not determined using software but a physical position (vertical (V) or horizontal (H)) of antenna. If you have dual polarization antenna this means that it uses two antenna as one to achieve both horizontal and vertical polarization at the same time. This has nothing to do with the card itself.
JF
