Where can I find documentation on the antenna configurations for R52Hn ?
It’s a 5GHz & 2GHz, but also 2x2 mimo … Because I know that the antennas need to be properly tuned to the frequencies, I assume that it can either be {2x2 MIMO 2GHz} OR {2x2 MIMO 5GHz} OR {5GHz 1x1 and 2GHz 1x1}. Is my assumption right ?
How do I configure the card for 2GHz 2x2 MIMO ?
How do I configure the card for 5GHz 2x2 MIMO ?
How do I configure the card for 2GHz on left connector and 5GHz on right connector ?
If I configure the radio as a mobile client MIMO configuration & I have the 2 antenna positioned where they usually DON’T SEE the same access point because I want more connectivity possibility. Will this confuse the DSP ? Say I have 2x 180 degree directional antenna placed at both end of a train.. Will this reduce the capability of the radio because it will be confused trying to multiplex or bond channels ?
I have this card connected to a Linux x86 processor, not a routerboard OS.
Kind Regards,
Martin Politick, June 2017.
