Is the R52Hn card compatible with the R52H? I have been trying to get this link to work but have not had any success. From the R52hn card I can see and associate with the R52h card but from the R52H card I can’t see the R52Hn. Was wondering if it is a compatibility issue or if I have some configured wrong. If it is compatible how should I configure it to talk to the R52H? This is my first time working with the R52 series cards. Any help would be appreciated.
Both cards are compatible within the 802.11a/b/g realm as well as with nstreme related protocols. They, of course, are not 802.11n compatible. There is a significant power difference between the two of them as well. Why don’t you post the settings you are using for both cards?
