People
I`ve a doubt. In cards like R52Hn with “N”, for use “n” I have to use both connectors and two antennas??
Thanks for you help
MsLrO
People
Thanks for you help
MsLrO
You can use a single antenna if you disable the unused connectors.
if, i disable the unused connector, can the card be set up as b/g/n??
jandafields:
MsLrO:
People
Thanks for you help
MsLrO
Yes, you can use a single antenna, but you won’t get max power or range.
