between 63 ~ 65 db
Do you have antennas connected?
no…
without antenn just for tests…
Thats a fast route to fried radios !
I run your export configurations…
and I dont get more than 65/65 Mbps
You’ve possibly fried your radio cards by not using antennas on them.
Add antennas, move the routerboards away from each other, and try again.
if the RX/TX power is greater than -30-35ish dbm move them further away.
ok…
I’ll test this with antennas
Do NOT use radios without antennas attached, otherwise you’ll blow up it up … ![]()
