R52HN + RB 344AH and Using MIMO
Hi, I am Aamir from Pakistan and planning to launch WISP with 2x RB433AH and both these boards will have 2x R52HN connected with sector Antenna. I want to ask,
1- how could I use MIMO for maximum bandwidth
2- What would be the maximum number of users at each radio (sector Antenna)
3- What frequency channel should I keep at each radio to avoid the interference
4- What would be the max range these radios will cover
Please reply me so I my confusions get clear as I am totally confused how and whether to use mikrotik or not ?
Regards
Isnt there any dude who can help me out in this matter please.
What If, I install 2 sector antenna at R52HN for mimo, would it work OR i need to have MIMO capable antenna ?? Plz Plz reply…
Connect each r52hn with 2 sectors. 1 for Rx n the other for TX. they shld be in the same direction side by side. max number of active users shld be 30-40 with simultaneous bandwidth ranging almost 10 mbps ,max range shld be 3 km on a 17 dbi sector. frequency used shld be the one which gives highest ccq%
Thank you very much mahnet. Would these antennas horizontal and vertical polarized or both could be same as one will be used for Tx and other will be used for Rx.
Let say, i have 512kbps users, in this, number of users will remain same (30-40).
I am planning to start with 4x sector of 90 degree. It means, i will have to start with 8 antennas for using mimo, 4 for Rx and 4 for Tx…
Thanks once again..
number of users will also depend on how well u handle broadcasts among users and yes u will need 8 sectors. Also keep all sectors TX-RX side by side but the Mast/Tower u have should be spaced 3 feet apart. Else interference wld kill lot of performance whn u r in a dense city with nearby towers etc.. 30-40 live users shld be good enuf but may be with 90 deg u can take dat to 50
Dormant users u can have as many as u like.
