I just wanted to have confirmed, that a 711 board really is way less sensitive than a R52Hn card, even if its the same chipset & manufacturer.
At 5 GHz
R52Hn has a rx senivity of 802.11a: –97 dBm @ 6Mbps to -80 dBm @ 54 Mbps
R711-5* has a rx senivity of 802.11a: –92 dBm @ 6Mbps to -76 dBm @ 54 Mbps
that means that you loss 4-5 dB sensivity when using the integrated board in comparision to the single card. thats a lot. can you confirm that ? (meaning I’ll stay at using the cards for senders)
I’ve had a few links like that, different values for different cards, exact same performance, even some of the same quirks with weather related issues.
I was JUST quoting the technical details from the mikrotik data sheets on the mikrotik website. so mikrotik says “rb 711” has a worse receiving sensitivity over R52Hn - and I wanted to have that confirmed.
