hello evrybody i have one question why when i test internet speed download is ok but upload is slow in r52hn i leave cofigure in default.i have to change anythink to improve upload?thanks
Is this for a point-to-point or just an AP? Please post /interface wireless export compact
no no its ap bridge i have rb 433 two other r52hn works perfect but he not work well in upload its very sllow in this card
Ok, still post /interface wireless export compact
sorry?i not understand
can help me pleasee?
Just click on “new terminal” and type as cbrown suggests
and then post the results here
set 0 antenna-gain=17 band=2ghz-b basic-rates-a/g=“” basic-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps disabled=no frequency=2422
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15
l2mtu=2290 mode=ap-bridge scan-list=default ssid=abc1 supported-rates-a/g=“” wds-mode=dynamic
set 1 band=2ghz-b disabled=no frequency=2442 l2mtu=2290 mode=ap-bridge ssid=abc2 wds-mode=dynamic
set 2 antenna-gain=17 band=2ghz-b disabled=no frequency=2457 ht-supported-mcs=
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15 l2mtu=2290 mode=
ap-bridge scan-list=default ssid=abc3 wds-mode=dynamic
set [ find default=yes ] group-ciphers=“” supplicant-identity=MikroTik unicast-ciphers=“”
antenna-gain=17
I normally set this gain to 0 and not the gain of the antenna
Also need to check wireless signal levels from the AP, they are from winbox in wireless registration click on entry and select signal tab
or /interface wireless registration-table
Also, why are you using 2ghz-B?
i set 2ghz b for better signal its not true?what you recommanded to me?
