I’m trying to use a RB433AH with the new R52N card. While I can get it to work in “N” mode at 2.4 Ghz, when I change the frequency band to 5 Ghz (N or A/N), all I get are timeouts. I’m using the RB433AH in AP-Bridge mode. Any ideas? I can get it to work with regular 5 Ghz mode (non-N).
we have seen issues with Macs that are using braodcom chipset - they can’t connect using 5ghz N mode, but they work in 2.4ghz.
We will try to find a fix for it.
