2 x 433 with R52N - v4.01rc1
XR2 cards in both routers are already running 1/4 channel and passing traffic fine.
I have a link I’m building on which I would like to try a half channel. I have everything working, and the slave registers just fine and passes traffic when I use 20 MHz channel width. No matter what permutaion of 1/2 or 1/4 I can not get them to register.
I have tried putting the ip in scan list and have just about exhausted possibilities. What’s the trick? Has anybody used these cards in a 433, v4.0rc1?
I’m going to have to put them into production at full bandwidth if I can’t figure this out.
I guess no response means it can’t be done, or nobody is doing it? I should think the MT cards would do it easier than the XR cards, but am probably mistaken. If there is anything I should try, or more info I can supply please let me know.
I am using dynamic WDS. The link works just fine with 20 MHz channel width. Just can’t see it when I switch to 5 or 10 MHz. I think I have everything set right, otherwise I wouldn’t be passing traffic with full channel setting, right?
Yea its seems the other mikrotik units can’t pick them up on 10 and 5mhz, but all my Ubiquiti gear can see and connect just fine to the N cards on 5 & 10mhz
