R52n-M, WLM200NX - Works only with NV2 problem
Hi, we came to a weird problem while testing 4 radio cards - a pair of R52n-M and a pair of Compex WLM200NX. We established a 100m test link with 24dBi MIMO antennas, got signals about -30dBm (lowered the TX power) on both sides, both chains. No interference at all - this is clear testing outdoor environment. Testing WLM-WLM, then R52nM-R52nM.
The problem was, we vere not able to run this link with 802.11 protocol (got 500kbps and less on BWtest, then reconnect). Using NStreme we got only about 15M/15M on BWtest and CCQ jumped from 30 to 80%, very unstable. Eventually the link would also disconnect.
However when we used Nv2, the link got CCQ 100% (both TX and RX), the data rate went to 130Mbps/130Mbps and we could do as much as 90Mbps HD, which is what we expected. The only thing I wonder about is why the hell 802.11 and NStreme protocols worked so bad? I checked polarities of antennas - matched. I checked pigtails - no problematic bends. Even tried to turn antenna to get worse signal (-60/-60) - had no effect.
Does Atheros AR9220 cards R52n-M and WLM200NX support only NV2 protocol on 2x2 MIMO??! Anybody came accross similar problem?
That really sounds like some kind of interference or ACK issue.
I’ve been going through the possibilities since I read your post this morning and that is all I can come up with.
I have a R52n-m card in a RB800 running i AP mode, works fine.
Nothing else except nv2 works for every links I have.
move those boards further away from each other and test again as the wireless signal is too strong.
