R5nH?
Hi. I was wondering if you can provide us with some more detailed specs adout this new card?
Are there any tests showing what data rates can it lock and what is the real traffic data rate
it can reach?
Thanks in advance
duman.
http://www.routerboard.com/
real traffic it can reach? all same standard cards have same theoretical maximum in perfect conditions. difference between cards is sensitivity, output power, connector type etc. that simply helps to overcome limitations such as distance.
I was reading the PDF’s, the R52n and R52Hn show around -94 rx sensitivity. The R5H shows -93. The R5nH shows -85 @ 6mb.
Is this a typo? That’s a pretty significant difference from the rest of MT’s cards.
Seen this too. Makes me wonder why I should buy R5nH as R52N is
better in sensivity and has a second chain as option with only a very
small price offset.
That is why we are not selling it. Sensitivity is very weak according to the data sheet.
Tom
No comment from MT?
http://forum.mikrotik.com/t/r5nh-1x1-mimo-card/36527/23
Funny how i found it on your website lol
