I have used two R5SHPN in RB433UAH.When I test them indoors,the power is much lower than R52HN in the same environment;Can anyone tell me the reasons or settings that makes power higher?Thanks a lot.
Read about SWR (assuming you have config all perfectly, as you assume)
http://en.wikipedia.org/wiki/Standing_wave_ratio
R5SHPN indoor?
Do not put your head in the microwave owen
