i have 35 k link i run router 433 on both side
i want to buy the new mikrotik R5SHPn 800 Mw but i heard that its have heating problem our area is hot in the summer it could reach 90 F
so did mikrotik developer recommend that i use this card please help ?
by use cooler inside the box can i solve this problem ?
no, this card loves the heat. it has no problems in hot ambient conditions.
testing this r5shpn now… is it normal that this card’s heatsink hot like iron heat?
i even can’t touch the heatsink.. it’s SUPER HOT!!
it’s super powerful, so yes, it gets hot. but it likes heat.
what is the normal maximum temperature for this card? 80 celcius degree?
We are looking to put one of these in an Acconet EN5820 enclosure.
These are made from plastic so I wonder if the heat will be an issue ?
You didn’t help anyone, you’ve just ask something. Why anyone should give karma for a question?
True- that was a footer set up in Tapatalk. Now modified ![]()
so you others also experienced with this heat problem?
