Rack Module
I want to buy more pieces of CRS125-24G-1S-2HnD-IN but I see they NOT have rack mount kit.
Does anybody know if exist and what is the part number for buy ?
Regards,
why this?
it is not for rack, use CRS125-24G-1S-RM
https://mikrotik.com/product/CRS125-24G-1S-RM
it is the same (but only without wifi)
LOL…brilliant answer !!!
If I did not know that, you think I was asking for that ???
Regards,
Asking as moderator:
Could you be so kind and DO NOT cite full post if you answer it. If you need to pertain to particular words then just cite them. Not all.
Sorry for that…I understand
I don’t think they are a MikroTik official part number however our distributor occasionally gets a good amount of additional rack mounted ears which we can order individually from them. Maybe speak with the local distributor?
Raises the question though, why do you want to rack mount that model? You lose the screen and hinder the wifi performance by trapping it into the back of a metal box?
https://mikrotik.com/product/CRS125-24G-1S-RM and a wap AC would be significantly better.
