Rack Mounted Chassis for Router
I am Searching for Rack mounted Chassis for Router.
I want to fix some motherboard in it and want to make like standard router.
Can any one help me find the same.
ASHISH
rack mounted needs special motherboards as i think .. special power supply ..
2U cases:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Description=2u+case
Favorite one with PS:
http://www.newegg.com/Product/Product.aspx?Item=N82E16856999304
If you want smaller do a 1U case. 1U’s seem awful cramped though and you will need a low profile fan.
Matt
Portwell makes good routers that work very well with Mikrotik. We use these devices for our main routers and PPPoE servers. They have a wide array of embedded computing devices, and rack mount servers for networking applications.
http://www.portwell.com/products/detail.asp?CUSTCHAR1=NAR-5520
There’s an example of one of their products. We’ve been using them for years now, great products. Didn’t have much luck getting the EZIO LCD’s to work, but that’s not a big deal to me.. They’re also worldwide!
Logic Supply has a nice selection of pre-built systems, cases and parts that make nice routers:
http://www.logicsupply.com/
