I’m running a pair of RB NetMetal 5 and a pair of RBD23UGS-5HPacD2HnD.
At first, the RBD23UGS-5HPacD2HnD started losing 4 packets every 370 packets.
I’ve rebooted, reconfigured, changed channel, etc etc.. and still the same. So when i tried to diagnose wich one was the problem, i’ve putted both on AP and connect another radio to them. When I did this, the problem desapear.
but now, the problem started to happen on another link, in netmetal 5 ones. The problem is/was localized in station side.
in this link packet loss is random, but with the same loss, 4 packets.
I’ve already tried V7, V6.. the field " connected to ess " in this ocasion, fills blank..
What makes you think that a radio channel has the same properties as a cable? Packet loss on the radio is a normal mode of operation. After all, you are using a common transmission medium and judging by CCQ you are not the only one using it.
those are some bad links… 60% ccq while idle at -50dB signal? wtf? that is probably dropping to unusable levels when you do a speedtest.
if it’s really such a traffic in the air, i’m surprised this thing even works.
DROP the 80mhz, even 40, and try to use 20mhz to get ccq up to the 90ish % and then do this again.
just look at the sync rate - 351mbit @80mhz, 114mbit @80mhz - this is terrible and your modulation is not keeping up because of all the interference.
could also be that you’re using wrong antennas
