Radio signal diminishes over time
I have a rb523a running 2.9.10 with the manual power settings for a SR2 radio. The radio seems to put out lower and lower power as time goes on. After 2 days, I get slow connect speeds, and then I do a system reboot (soft reboot, not power off) and the radio strength goes back to normal… Any ideas what might cause this. I just upgraded to 2.9.13 in case it will help. Please advise.
search the forums
enable periodic calibration in the wireless advanced menue
Thanks. I assume the interval is in minutes? the manual does not say.
search the forums
Sten, I spent an hour searching the forum before I posted and found only one article similar in structure to my post, and it gave no final recommendation. Lighten up :stuck_out_tongue:
