We set up a nice hotspot that consists of 4 radios behind a rb-450g, the issue at hand is we cannot get to the radios remotely unless we shut down the hotspot server, If we plug into the 450g directly then we can get to them some what consistant. We tried making rules to allow the address of radios to not need to athenticate but no luck. We have proxim dual radios plugged into the 450g then it links 5.8 to another ap and so on all radios are dual, 2.4 for customers and 5.8 backhaul. We ariginally had a unit running dd-wrt in here and from the 2.4 side we could get to all radios with no issues, So i know its in the setting up of this hotspot thats stopping us but im lost on why when we plug in we can get to the radios but wireless nothing.. Any help would be greatly appreciated..
I don’t know where you tried the rules, but the correct place is
/ip hotspot ip-binding
add address=xx.xx.xx.xx type=bypassed
Change xx.xx.xx.xx to the ip of the radio. Repeat as necessary.
Thats what we did, still no luck. any further ideas would help out greatly.
How is your ip addressing set up? Have you routed all the ip sets to the correct interface? If your localnet range is not assigned to a local interface, you will need to install a route so the router will know which interface the localnet addresses are on.
