Hi, I want to run Mikrotik router as NAS, but I seem to have a problem with Radius configuration.
Seems the problem is in the accounting commands that the router sends to Radius server. Router sends ACCOUNTING_ON (and probably ACCOUNTING OFF) instead of ACCOUNTING_START / ACCOUNTING STOP.
Radius log:
unsupported acct status received=
Any way I can fix that? Any suggestions?
what RADIUS do you use? FreeRadius works fine
Microsoft IAS (Internet Authentication Service) with proprietary billing solution.. Is there a way to change command that is being sent to Radius server (manually modifing some file would not be a problem).
proprietary? so change your packet handlers in RADIUS
I figured it out. It was configuration issue. Now works as it should. Thank you for your attention.
