RADIUS accounting stop request not sent: no response
Hi I am facing RADIUS accounting stop request not sent: no response, repeatedly I am using hotspot, due this RADIUS accounting stop request not sent: no response errors some of my users getting logins repeatedly, and even I changed Radius server timeout to 3000ms. Please help me out. I am attaching screenshots for reference
without see the FULL configuration of the radius (firewall included) and the client, can be everything…
I have the same problem.
And
RADIUS accounting request not sent: no response
It’s Errors and warnings.
I thought it because I had moved user manager DB to sd card and there is problem with the card. So, I moved back to system storage (128MB) but problem still exists.
I had checked sqlite DB with pragma integrity_check and pragma quick_check; but seems to not be corrupted. I can’t see any data because it is in BLOB (ROS 7, UM 5).
I have to change RADIUS timeout to 10000ms but there are still warnings but less.
Here is my config.
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" \
    disabled=yes
    established,related,untracked
    invalid
    "Accept all from VLAN 100 to internet. (by vee)" in-interface=vlan100
    "Accept all from VLAN 101 to internet. (by vee)" in-interface=vlan101
    "Accept all from VLAN 102 to internet. (by vee)" in-interface=vlan102
add action=accept chain=input comment="Accept RADIUS authentication. (by vee)" \
    dst-address=127.0.0.1 dst-port=1812 protocol=udp
add action=accept chain=input comment="Accept RADIUS accounting. (by vee)" \
    dst-address=127.0.0.1 dst-port=1813 protocol=udp
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack; This \
    need to be disabled to make hotspot speed limits work (vee)." \
    connection-state=established,related disabled=yes hw-offload=yes
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
    "Block access from non management IPs to ISP router. (by vee)" dst-address=\
    192.168.26.1 src-address-list=!internal-devices-adl
/ip hotspot profile
add dns-name=instant.hotspot hotspot-address=192.168.241.1 http-cookie-lifetime=1d install-hotspot-queue=yes name=\
    hsprof1 radius-interim-update=10m rate-limit=200M/300M use-radius=yes
/ip hotspot
add address-pool=hotspot-pool1 disabled=no idle-timeout=1h interface=vlan101 keepalive-timeout=1h name=\
    hotspot-vlan101 profile=hsprof1
/ip hotspot user profile
set [ find default=yes ] idle-timeout=23h keepalive-timeout=1h session-timeout=23h shared-users=2
/radius
add address=127.0.0.1 comment="Hotspot RADIUS (by vee)" service=hotspot timeout=10s
/radius incoming
set accept=yes
/user-manager
set certificate=*0 enabled=yes use-profiles=yes
/user-manager profile-limitation
add limitation=user-limits profile=wifi-until-checkout
/user-manager router
add address=127.0.0.1 name=router1
CPU usage: very little, less than 25%
Memory: less than 13% of 1024MiB
Edit: This ( https://forum.mikrotik.com/viewtopic.php?p=1024272#p1024272 ) seems to be fixed.
