Is there a Radius Attribute that sets the local Address in the PPP Profiles. I know there is one for Remote address but I need one to set the gateway address for the Users. Also is there one for DNS server? DNS is not as big of a deal but it would be nice to have.
Well the problem I am running into is that I have two different local addresses on the same interface. If I leave the local address field blank then it won’t work. If I build to servers and set one of the Two IPs in each of them then it will always assign the ip of the last server in the list as the local address. I am just wondering if there is a way that radius can tell the mikrotik which server to pick so that it gets the correct local address.
Thanks for the DNS attributes as those will come in hand once I have this figured out better.
There is a solution for this, but you’d have to manage your IP Addressing with MT IP Pools (Which I don’t particularly like when I’m using Radius).
Create a IP Pool, use the PPP Profile for your dialups.
Read the MT Documentation about I believe, Framed-IP-Address. I haven’t checked the docs myself - feel free to do so, but I believe you can tell the MT which PPP Profile to use for Address management via Radius. Then your Local-Address will be picked up from the PPP Profile, as would your remote IP, but your problem should be solved.
From the MT Docs (http://www.mikrotik.com/docs/ros/2.9/guide/aaa_radius)
[qoute]
Framed-Pool - IP pool name (on the router) from which to get IP address for the client. If specified, overrides Framed-IP-Address
[/qoute]
Thats basically what you need to use, instead of Radius Managing the IP Addresses via Framed-IP-Address.
The only problem is that the local pool attribute changes the client address to use the pool not the local address. I have looked and I have not been able to find any radius attribute that allows you to select which ppp profile to use. If I can find that then all my problems will be solved.
I have found this attribute, Ascend-Client-Gateway, but is shows it is only supported for hotspot users. Is this ever going to be supported for PPP users?
I believe this is what I need but it doesn’t appear to be supported.
I was just looking and if you create users on the mikrotik it gives you the ability to select which profile that user will use. Why is this not supported in radius to allow you to send which profile a user will use? This is exactly what I need but I can’t find anything in radius to support this.
Thanks again for any help anyone can give me as I am running out of Ideas here.
reply to add dynamic interface to a specific VRF routing table to create L3VPNs
ppp-profile
We are actally at a stage of having to make a decision if we need to change router brands at all our highsites because of this limited functionality. We currenlt have to make use of ppp>secrets to configure some services, and would much rather do this from our central RADIUS server.
Still not possible. We have to make use of Secrets and different PPP Profiles across over 70x routers to do what we need to do without this feature. We would much rather prefer to assign local addresses, DNS, profile, etc using RADIUS replies…
Similarly, it’d be great if we could use RADIUS to specify the profile to use for a PPP/VPN connection. There’s already a Mikrotik-Group attribute which would be meaningless on a PPP session. Could MikroTik re-use that for profile name on PPP?
