I’m trying to set up my RB1100 for login using Freeradius. I followed the steps outlined on Wiki but it’s not working. Here’s some of the configs. Hopefully someone can help me figure out where I went wrong. RB1100 and RADIUS server on same LAN segment. Thanks!
from clients.conf
# added clients
client 192.168.1.1 {
secret = xxxx
from users.conf
ex Cleartext-Password := "1234"
ex2 Cleartext-Password := "5678"
Group = "full"
from dictionary
# This is the master dictionary file, which references the
# pre-defined dictionary files included with the server.
# Any new/changed attributes MUST be placed in this file, as
# the pre-defined dictionaries SHOULD NOT be edited.
# $Id$
# The DHCP dictionary is used only when the server is built with
# "configure --with-dhcp". It is not (and should not) be used in
# other situations. If you are running just a RADIUS server, this
# line can be deleted. If you are using DHCP, the following line
# should be uncommented.
# Ideally, the "configure" process should automatically enable this
# dictionary, but we don't yet do that.
#$INCLUDE /usr/dictionary.dhcp
# The filename given here should be an absolute path.
$INCLUDE /usr/share/freeradius/dictionary
# Place additional attributes or $INCLUDEs here. They will
# over-ride the definitions in the pre-defined dictionaries.
VENDOR Mikrotik 14988
ATTRIBUTE Recv-Limit 1 interger Mikrotik
ATTRIBUTE Xmit-Limit 2 interger Mikrotik
ATTRIBUTE Group 3 string Mikrotik
ATTRIBUTE Wireless-Forward 4 interger Mikrotik
ATTRIBUTE Wireless-Skip_Dot1x 5 interger Mikrotik
ATTRIBUTE Wireless-Enc-Algo 6 interger Mikrotik
ATTRIBUTE Wireless-Enc-Key 7 string Mikrotik
ATTRIBUTE Rate-Limit 8 string Mikrotik
# See the 'man' page for 'dictionary' for information on
# the format of the dictionary files.
# If you want to add entries to the dictionary file,
# which are NOT going to be placed in a RADIUS packet,
# add them here. The numbers you pick should be between
# 3000 and 4000.
#ATTRIBUTE My-Local-String 3000 string
#ATTRIBUTE My-Local-IPAddr 3001 ipaddr
#ATTRIBUTE My-Local-Integer 3002 integer
RB110
[admin@RouterOS] /user aaa> print
use-radius: yes
accounting: yes
interim-update: 0s
default-group: read
exclude-groups:
[admin@RouterOS] > radius print
Flags: X - disabled
# SERVICE CALLED-ID DOMAIN ADDRESS SECRET
0 login 192.168.1.101 xxxx
Let me know if more detail is needed and if so what you’d like to see. Thanks again!
