radius authentication wifi with wifi-qcom-ac 7.13rc3
Does anybody know if radius authentication with an external radius servers works with the new drivers wifi-qcom-ac 7.13 to allocate different vlans to clients? My setup worked very well on V6 with capsman. Currently and trying to do the same on 7.13 and struggling to make it work. Read about the issues with vlan assignments but not sure if this affects radius authentication also. At the moment just trying to make one AP work with wifi radius authentication beforing adding capsman. With wpa2-psk i manage to make the configuration work with an untagged vlan.
Current config below
add name=bridge vlan-filtering=yes
/interface wifi
SSID not set
set [ find default-name=wifi1 ] configuration.manager=local .mode=ap disabled=no
/interface vlan
add interface=bridge name=MGMT vlan-id=217
/interface wifi security
add authentication-types=wpa2-eap,wpa3-eap disabled=no eap-accounting=yes name=sec1
/interface wifi
set [ find default-name=wifi2 ] channel.band=5ghz-ac .skip-dfs-channels=all .width=20/40/80mhz configuration.country=Romania .manager=local .mode=ap .ssid=B1 disabled=no security=sec1
add bridge=bridge interface=ether1
add bridge=bridge frame-types=admit-only-vlan-tagged interface=wifi2 pvid=320
/interface bridge vlan
add bridge=bridge tagged=ether1,bridge vlan-ids=217
add bridge=bridge tagged=ether1,bridge untagged=wifi2 vlan-ids=320
/interface wifi cap
set caps-man-addresses=172.17.0.251 discovery-interfaces=ether1 slaves-static=no
add address=172.17.0.169/24 interface=MGMT network=172.17.0.0
set servers=192.168.13.200
add distance=1 gateway=172.17.0.254
/radius
add accounting-port=2041 address=XX.XX.XX.XX authentication-port=2040 service=wireless
/radius incoming
set accept=yes
/system clock
set time-zone-name=Europe/Bucharest
/system logging
add topics=wireless,info
add topics=caps,info
add prefix=error topics=radius
/system note
set show-at-login=no
/system package update
set channel=development
Any advice would be appreciated:)
Is this issue already solved as it is marked as it is in this post: radius authentication wifi with wifi-qcom-ac 7.13rc3 - #8 by gustavohellwig
If yes, how?
Thank you!
When will those devices support dynamic VLAN assignment from the Radius server, which most major companies use?
