Radius authentication
Hi all,
I was setting up a Radius server today for use by the hotspot in mikrotik RB951Ui. It seems to be working as I was able to authenticate a few test users on the landing page of mikrotik hotspot.
My questions is, after I authenticate the user, what is the default time before they need to authenticate again?
Also, is there a way to force disconnect after a certain period of time, say 30 minutes?
Thanks for your help
http://wiki.mikrotik.com/wiki/Manual:IP/Hotspot
http://wiki.mikrotik.com/wiki/Manual:User_Manager
Thanks. Yes I’m aware of these. But as far as I understood, you define the profile that the router assigns on a user is defined on the router. Is it possible to define the “session-timeout” of a user from the radius server? I mean, the radius server will push settings to the mikrotik router depending on each user who authenticates.
I’m using mysql for radius.
Thanks again.
Hi there,
I don’t know if this will help but it’s something I’m working on as well.
If you use FreeRADIUS with MySQL you can enable the “Disconnect Message” part (I’d have to look but it’s in the wiki at freeradius.org) and then enable incoming RADIUS on the Mikrotik under the RADIUS section.
It’s my understanding that FreeRADIUS can disconnect a client on the NAS (MikroTik) by “pushing” a disconnect message back to them based on your needs.
If you are using the MikroTik itself for RADIUS I believe there is a session timeout in Hotspot, maybe under profiles… I can dig some more if you like.
